Re: (H) rod orientation
Posted by riverbend on April 05, 2004 at 07:10:21 from (208.160.33.209):
In Reply to: (H) rod orientation posted by Jonathan Mirgon on April 05, 2004 at 06:13:12:
The flat spot where the rods and caps are marked goes towards the cam. Use 0.005" feeler gauges along side the rod / cap joint to make sure they are aligned properly when tightening the rod bolts (40 ft. lb.). If they feel too tight (slightly twisted), remove and reinstall the caps.
Post a Followup
: Re: Re: (H) rod orientation
