Farmall H Transmisson Leak
Posted by Dennis on April 11, 2004 at 19:59:00 from (65.163.45.93):
I have a Farmall H tractor that leaks transmission fluid from the front shaft area between the "lift all" pump and the transmission. I plan on repairing it. The manual I have does not explain the procedure. Does anyone one have experience on this matter?
Post a Followup
: Re: Farmall H Transmisson Leak
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
