H carb and clutch
Posted by Doug on April 15, 2004 at 12:52:30 from (65.176.81.232):
Have a new motor in a 1948 H. Been trying to dial in the carb I rebuilt with little luck. Can only get it to run with the choke closed. Tried to turn in the idle screw to give it less air as I open the choke but still getting too much. Was wondering if the mainjet could be sucking air too. Have a new mainjet that came with a piece of packing. Where does the packing go? Tried to adjust by the sequence they give in the manual but didn't work either. Starting with the mainjet 3 turns out and the idle screw 1 turn out. Turned the govenor control screw to open the butterfly slightly until the rpm picked up a bit, but still can't get it dialed in. Valves are OK at 0.017. Also, can you replace the clutch shaft seal without splitting the tractor. Looks like you may be able to remove the u-joint type knuckle from the under side to get at it. Leaking gear oil bad from the differential around the clutch shaft. Mostly only when in reverse. Probably another original leather seal. Thanks for the help.
Post a Followup
: Re: H carb and clutch
