Low Oil Pressure on H
Posted by RH on April 15, 2004 at 19:28:39 from (64.12.117.22):
My H has very low oil pressure according to the gauge. Once the tractor gets hot it shows hardly none. The tractor doesnt smoke and seems to be very strong under a load.(although no hard load has been put on it for long periods) I would like to fix this problem if there is one before it causes me to lose the engine. Any suggestions will be very helpful on where to start or what to look for on the oil pump for problems? Thanks
RH
Post a Followup
: Re: Low Oil Pressure on H
