Farmall Tractors Discussion Board
Re: Engine knock F-20
Posted by The Red on October 24, 1999 at 14:58:26 from (12.75.197.12):
In Reply to: Engine knock F-20 posted by Randy on October 24, 1999 at 13:02:51:
My suggestion would be to drop the oil pan and inspect the rod bearing connection. If it is tight, then it sounds like a worn rod bearing.
Post a Followup
: Re: Re: Engine knock F-20
