Re: Re: Re: Farmall M
Posted by rustyfarmall on May 09, 2004 at 12:16:38 from (216.248.75.170):
In Reply to: Re: Re: Farmall M posted by Jamie Stratton on May 09, 2004 at 11:42:10:
The tractor does not need to be in gear, but the clutch does need to be engaged, your foot off the pedal. Yes, the fitting up on top is for filling the hydraulic reservoir.
If you noticed, the rod, or lever, has a small peg on the bottom side, you need to lift up on the rod, so that you can bring that peg past the the support bracket that it rests in, continue pulling it toward you until you feel resistance, at which point you should also notice a differance in the sound of the engine.
Post a Followup
: Re: Re: Re: Re: Farmall M
