Re: Re: Re: H vs JD 70 D plowing
Posted by CNKS on May 10, 2004 at 07:14:40 from (207.178.99.120):
In Reply to: Re: Re: H vs JD 70 D plowing posted by riverbend on May 09, 2004 at 20:21:23:
The key is not to lug the tractor. Having spent probably 5000 hours on an H as a teenager before I left the farm (I drove many other tractors in later years, and still piddle with an H), I know what the engine is supposed to sound like. If it does not get to it's rated RPM of 1650 in a few seconds, it is overloaded. Idle RPM is 1815, so there will definitely be an RPM drop under load--but it should be able to maintain that RPM, except for a few times when it is pulled down and rapidly recovers. You really don't need a tach. If as you say, it does not overheat, and it does not appear to be lugging, then you are ok. But the engine has to recover quickly from a "hard spot" or you will have problems later on, I can't say how long it will last. I mentioned valves, because they seem to be the first thing to go. I have been able to pull very few tillage implements in fourth. Conversely if it will not pull in second, and you have any acreage at all to do, you need a bigger tractor. I usually pulled a plow in second, disks and finish implements in third.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
