Re: M throttle
Posted by Bob M on May 11, 2004 at 09:22:21 from (165.170.128.65):
In Reply to: M throttle posted by Ted on May 11, 2004 at 08:39:28:
Ted- Most likely the governor to carb throttle shaft linkage is binding. Suggest you proceed like this: 1 - Remove the sloped cover from the top of the governor riser (it’s the cover with the vent tube running from it to the head). With the governor handle set at idle try to move the bellcrank by hand - it should move up and down freely. 2 – If the bellcrank is binding, remove the pin from the bellcrank Now try moving the governor rod (the vertical link) up and down, and rotating the throttle shaft (the horizontal shaft) back and forth to figure out which one is binding. 3 – If you find the throttle shaft is stiff, try loosening (but don’t remove) the two screws in both the retaining plates at both ends of the throttle shaft tube. Wiggle the tube around then retighten the screws. If the throttle shaft is still stiff, the problem’s in the carburetor (bent or sticking throttle plate shaft). You’ll need to remove the carburetor to fix. 4 – However if it’s the governor riser rod that’s sticking, it’s time to go inside the governor. Problem could be a worn out thrust bearing, worn rockshaft bushings, a simple buildup of sludge, etc.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
