M throttle
Posted by Ted on May 11, 2004 at 08:39:28 from (144.71.145.22):
I have a problem with my Super M on applying the gas throttle up and down. When increasing throttle you move the lever one or may two notches and there is know response. But, if you move maybe four notches you get a response but then its more then you wanted. The same thing occurs going down. Also if you move the throttle lever all the way down to idle position, it will not idle down all of they way unless you give the throttle a rapid up and down movement. Any help would be appreciated.
Post a Followup
: Re: M throttle
