Re: Will 85W-140 GL5 gear oil be ok in my trans/di
Posted by Don L C on May 13, 2004 at 11:00:21 from (24.166.243.249):
In Reply to: Will 85W-140 GL5 gear oil be ok in my trans/diff? posted by Greg on May 13, 2004 at 10:44:33:
140 is a little stiff in the winter temps......if you live in a mild year around temp. it will be OK.....If it is hard to shift gears, you could add a qt. or two of heating oil......
Post a Followup
: Re: Re: Will 85W-140 GL5 gear oil be ok in my trans/di
