Re: Re: Will 85W-140 GL5 gear oil be ok in my tran
Posted by Greg on May 14, 2004 at 12:03:19 from (4.227.126.111):
In Reply to: Re: Will 85W-140 GL5 gear oil be ok in my trans/di posted by Don L C on May 13, 2004 at 11:00:21:
Don, the tractor is run in the East Texas area and winter's are very mild. Rarely below freezing but the summers pound us with 100+ heat regularly. I bet it will be fine. I'm not worried about the hard shifting but was concerned about it doing a good job lubing all the gears and bearings and hurting my trans in the long run. The tractor will be run mostly in the summers so I feel ok about it now.
Post a Followup
: Re: Re: Re: Will 85W-140 GL5 gear oil be ok in my tran
