Re: International 464 diesel
Posted by buck on May 13, 2004 at 21:38:50 from (209.240.205.63):
In Reply to: International 464 diesel posted by Hazlett on May 13, 2004 at 20:37:31:
Pedal is traction lock--locks both rear wheels together so they pull the same. should lock wheels when depressed and release wheels when you release the pedal-otherwise does sorta appear stuck. fluid in tires,wheel weights.heavy implement on 3 pt. or a drum fixed to attach to 3 pt. and filled with sand,gravel ets or even a drum of water on a carryall will add the needed weight to rear. Very nice tractors.
Post a Followup
: Re: Re: International 464 diesel
