Farmall H Steering Gear
Posted by Garrison on May 14, 2004 at 06:57:40 from (199.248.201.204):
I have an H and I am Redoing the steering but i cant get the steering sector out. It says to use a puller in the servive manual but even the smallest puller i have wont fit between the steering gear housing and the sector. I jacked up the front of the tractor and put the old castle nut back on the top of the shaft and used a hammer to try to tap the shaft down but that didnt work so what can i do to get that gear off?
Post a Followup
: Re: Farmall H Steering Gear
