Re: Farmall H Steering Gear
Posted by Bob M on May 14, 2004 at 10:28:18 from (165.170.128.66):
In Reply to: Farmall H Steering Gear posted by Garrison on May 14, 2004 at 06:57:40:
Garrison -
That sector gear is on a tapered spline on the pivot shaft – sometimes they can be a real SOB to get loose. Like the other Bob suggests you’ll probably need to beat on the shaft to break it loose from the gear.
I’ve found it helps to remove the lower bolster + front wheels by unbolting at the pivot shaft flange. Otherwise much of the force of each hammer hit is absorbed by the mass of the lower bolster and wheels. Also to protect the threads lay a chunk of soft metal (scrap copper or aluminum bar) on top of the pivot shaft, or use a HEAVY brass drift (the shorter and fatter the better….) between the hammer and the top of the shaft.
The couple I’ve done required several heavy blows with an 8# hammer before they broke free.
Post a Followup
: Re: Re: Farmall H Steering Gear
