International farmall Loboy 154
Posted by Bob Oliver on May 19, 2004 at 08:17:51 from (65.162.15.229):
Our son has an Interational Farmall Loboy 154. It has no power to the transmission.
Shaft works but nothing else does inside the case.
Would you have any suggestions as to what to look for or how to fix it?
Would it be possible to obtain a diagram of the transmission?
Any help would be greatly appreciated.
Bob Oliver
Post a Followup
: Re: International farmall Loboy 154
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
