F 20 carbuetor
Posted by gary on May 20, 2004 at 04:59:51 from (160.136.109.4):
I have a 1938 F 20 I get condensation at the point of where the carbuetor baolts to the manifold and I cannot adjust the carbuetor, do I need to rebuild the carb and replace the gasket, or is there another problem. the engine runs a little erattic but under load it smooths out.
Post a Followup
: Re: F 20 carbuetor
