Re: Re: Re: Help for IH 1486 Hydraulics
Posted by the tractor vet on May 22, 2004 at 17:22:29 from (216.196.13.201):
In Reply to: Re: Re: Help for IH 1486 Hydraulics posted by Francisco Lopez on May 21, 2004 at 18:08:20:
Ok , easy way to tell if ya got open center or the PFC loolk on the lower part of the right hand control pannel down by the cab floor and if there are two - three colored small levers then it is a PFC system if not then it is the open center and also if it is a later modle then it is a PFC but i don't remember if it was 79 or 80 that they started using the PFC . You can do a flow check with a pressure gauge a high pressure valve and a container that will hold ten gal of oil and a watch , Get a couple pices of 1/2inch hdy. hose and some fitting and install the pressure gauge inline then install the valve after the gauge and then the othere pice of hose into the container plug into one of the remotes and warm the hdy. up to operating temp and run the engine at pto speed and open the remote valve and hold and shut the valve and see at what pressure the releif kicks out you will have to hold the remote valve open as it will kick out first . Make sure that you don't run the system out of oil, i do the releif test withe hose dumping back into the fill tube first then the bucket , just don't hold the releif test for more then a few seconds . then with the valve open do a 30 sec. full flow into the bucket and see how many gal. you got then times two is about what the pump is putting out then do a test with a 1000 psi on the gauge by closing the valve part way and see how many gal. you get in thiry sec. . Now on to part two of the problem the MCV there are new spring kits out there i have always got them from HY CAPACITY along with the new gskt. kit and my pumps , This may mean a trip across the border.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
