Re: ' 40 Farmall M Ignition
Posted by jal-SD on June 03, 2004 at 05:58:59 from (64.68.183.19):
In Reply to: ' 40 Farmall M Ignition posted by Rusty on June 02, 2004 at 20:51:07:
Mags & distributors from A's, B's C's & all the Supers are also the same. IH began to sell both IH & Delco (the right angle ones) distributors to replace mags in the '50's & there are a lot of them out there. You can use any of them to replace a mag. Allis Chalmers also used the Delco's & they will work, too. Any 4 cylinder distributor that has the same flange will work, but you might have to figure out the rotation & match it to your firing order. We've used IH stuff on Case's so if you find a good Case mag, it will work as well, but parts for Case mags are nearly impossible to find. (My $0.02 worth. jal-SD)
Post a Followup
: Re: Re: ' 40 Farmall M Ignition
