Re: farmall super c oil pressure
Posted by G Cole on June 14, 2004 at 17:43:12 from (64.91.1.94):
In Reply to: farmall super c oil pressure posted by john in ohio on June 14, 2004 at 16:21:44:
Had the same problem. When I took the pump apart I found the bottom plate was warpped. It would let the oil blow out instead of pumping it. The gasket was also shot. I laid the plate down flat on some sandpaper and lept moving it back and forth until it was level. I now have 65 lbs. Watch the gasket size. VERY important. Got my info the same way. Does yours have a 2 point?
Post a Followup
: Re: Re: farmall super c oil pressure
