Re: Re: Re: BD154 resleeving - help...
Posted by El Toro on June 16, 2004 at 06:13:28 from (64.12.117.22):
In Reply to: Re: Re: BD154 resleeving - help... posted by Greg on June 15, 2004 at 12:51:17:
Hi Greg, I'm sure IH has a tool for pulling those sleeves. I've never worked on a BD154. You may not need to replace the sleeves since your tractor has been serviced regularly. If it starts using a considerable amount of oil then you may want to rebuild the engine. You may only need to install new rings and bearings. You would want to measure the sleeves and pistons for wear. If the sleeves are out of wear limits, then you would have to replace the sleeves.
I restored 5 or tractors only the Farmall had sleeves and the engine was seized. I used a wooden block to drive out the pistons. Some of the sleeves came out too. I had a piece of aluminum round stock machined to fit the other
sleeves and drove them out. These were wet sleeves. Your sleeves are probably dry and are pressed in. Get a good shop manual before you
start. Good Luck, Hal
Post a Followup
: Re: Re: Re: Re: BD154 resleeving - help...
