Re: Help with cub carb
Posted by Rudi on June 29, 2004 at 05:53:45 from (69.195.159.117):
In Reply to: Help with cub carb posted by Mag Man Jon NY on June 29, 2004 at 05:09:29:
Jon: Sorry didn't answer last night, but hey, we had to vote in a new government and I was working the polls all day! And, we did answer the question. The Zenith is the correct replacement Carb for the Cub. The fuel line fitting may or may not be correct, as those usually have been modified/changed/field engineered by previous owners over the years. Without seeing a pic of the carb setup, it is awful difficult to get a really comprehensive answer as well. If you can email me a pic, I will post it for you and that should help with that problem. Also, if you cut and paste this url into your browser it will bring up the Zenith parts pages on the server : http://www.cleancomputes.com/Cub/Zenith Carburetors/Zenith - 1.jpg and http://www.cleancomputes.com/Cub/Zenith Carburetors/Zenith - 2.jpg Why in the world btw, would you have to pull the main jet to check the oil? If you need to remove the fuel line to access the cap????, would suggest you turn the fuel flow off at the bowl under the tank, then disconnect the fuel line. Also, the fuel line originally was steel (can be replaced with steel brake line) and was routed so that it was not in the way, yet did not have too many bends and curves that might affect gravity feed flow. Also, if I remember correctly, I gave you the info that you would need by providing the links to the service, parts and owners manuals. This should help as well. As for the rad cap - well hey, the part number was quoted, but 90 percent chance the dealer will not have it as it is no longer available. Use a less than 4lb pressure cap. This would be sufficient. Do not use a pressurized cap about 4lbs and the Cub uses a thermosyphon system. Now,if you have fuel, spark and air the Cub should run. But the spark must be correct so check the gapping on the points and the plugs - ensure they are as per the service manual. Make sure that all your contacts are clean, check for shorts etc., and that your grounds are good. Hope this helps
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
