Re: Gov/Mag drive gear timing on a BN
Posted by Red Dave on June 29, 2004 at 08:36:49 from (24.104.94.34):
In Reply to: Gov/Mag drive gear timing on a BN posted by Steve W (NY) on June 29, 2004 at 07:04:07:
The magneto does not run at the same speed as the crankshaft. You can line up the marks and still be off.
The easiest way I have found is to take out the spark plugs, put your thumb over the #1 plug hole and have somebody crank it over slowly. When the pressure from the compression pushes your thumb away, feel in the hole with a screwdriver or piece of wire for the top of the piston. Get the piston to top dead center of the compression stroke, then replace the magneto with the rotor pointing at the plug wire for #1. Should be in time then.
Post a Followup
: Re: Re: Gov/Mag drive gear timing on a BN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
