Re: Re: Timing a M Farmall
Posted by Dick Davis on July 04, 2004 at 02:58:32 from (152.163.253.103):
In Reply to: Re: Timing a M Farmall posted by TDK on July 03, 2004 at 22:53:40:
Any chance the timing is 180 degrees off? Has the distributor been off or could anything have changed the gearing to the dist? Pull the rotor cap off and watch the rotor while someone turns the motor over. TDC on the crankshaft mark and rotor movement should tell you if you're 180 out. Good luck Dick Davis
Post a Followup
: Re: Re: Re: Timing a M Farmall
