Re: 1256 engine vs. 1456
Posted by Dan 1256/806 on July 09, 2004 at 18:48:49 from (64.12.116.14):
In Reply to: 1256 engine vs. 1456 posted by Dan on July 09, 2004 at 06:48:36:
Update: Took it apart today. Teeth from one of the timing gears were laying in the pan, no visible damage to valves or cylinder tops, 3-4 bent push rods. We will probably remove engine from frame because of how we have the tractor split and the stands we use. Any idea on what caused these teeth to fail? Thoughts from you guys about what to and what not to replace? We will probably do a complete overhaul, but maybe skipping the cam if it looks undamaged and the lifters are all right. There is no scarring in the sleeves, and you can only feel the slightest rise when running your finger from the wore to unworn part of the sleeve.
Thanks for all the info RPM
Post a Followup
: Re: Re: 1256 engine vs. 1456
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
