Re: problem with tractor shutting down when hot
Posted by agmantoo on July 11, 2004 at 16:43:06 from (206.228.212.149):
In Reply to: problem with tractor shutting down when hot posted by mike on July 11, 2004 at 11:32:40:
I think there is a small pipe plug in the bottom of the carb. Carefully remove that plug and clean the hole then reinstall the plug only snug. When the tractor stops running remove the plug and observe the gas flow out the hole. It should be a continuous stream nearly the size of a pencil. Anything other, then the fuel supply line is clogging at the fuel tank. To fix the clogging problem install (solder or epoxy) a barb fitting in the fitting that screws into the fuel tank. Prior to inserting the fitting back into the tank connect a length of flexible gas hose to the barb and feed all that into the tank. Then fish the hose out thru the fuel filler hole in the tank and connect a generic inline fuel filter small enough to drop thru the fuel filler into the tank. Now you have a filter that you can service from time to time. I always buy the largest size filter I can get that will fit thru the filler hole, lasts longer.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
