Re: problem with tractor shutting down when hot
Posted by DENNIS on July 11, 2004 at 17:47:37 from (207.230.210.238):
In Reply to: problem with tractor shutting down when hot posted by mike on July 11, 2004 at 11:32:40:
had the same problem with my 560 ***** I disconnected the gas line at carb and took compressor and blew back into tank **** MAKE SURE YOUR GAS CAP IS OFF and as little gas in tank as possible because gas is going to splash out *** after you do this make sure you put a in line fuel filter in ***** good luck dennis
Post a Followup
: Re: Re: problem with tractor shutting down when hot
