1947 Farmall A electrical issues
Posted by Ted on July 19, 2004 at 07:38:28 from (208.1.81.16):
On my 1947 Farmall A, I am experiencing a drain of 0.3 volts when I test between the positive terminal and the positive ground ground wire (when the cable is un-hooked and the voltage regulator wires are also un-hooked).
When the voltage regulator is connected, I show a full 8.3 volts drain between the same battery post and the cable (I installed an 8v battery). (lights off, etc).
I have replaced ALL the wiring since, and no solution. When I connect the battery cable to the battery, the switch area starts to smoke.
SO now I'm trying to trouble shoot the problem. 1) Does anyone have a wiring diagram for the light switch so I can test that with my multi-tester?
2) Could I have mutliple problems (also regulator issues or generator issues)?
Any help would be appreciated.
Post a Followup
: Re: 1947 Farmall A electrical issues
