Re: 1947 Farmall A electrical issues
Posted by David in UT on July 19, 2004 at 12:56:28 from (208.15.63.194):
In Reply to: 1947 Farmall A electrical issues posted by Ted on July 19, 2004 at 07:38:28:
Ted,
Hmmmm...sure sounds like you've got a short-to-ground in there somewhere...can you trace the burned wire to its source?
It's the light switch you're working on right (not the ignition switch)? When I did my C, I had to figure that out too -- I did it by using the continuity tester on my multimeter. By testing different pairs of connectors, I was able to figure out which one was what...but I sure can't remember now ;-). I've got a diagram at home I think -- when I get in tonight, I'll look it up for you.
- David
Post a Followup
: Re: Re: 1947 Farmall A electrical issues
