Re: Re: Farmall H coil 6 volt/ 12 volt difference?
Posted by K-Mo on July 20, 2004 at 10:12:38 from (65.169.189.2):
In Reply to: Re: Farmall H coil 6 volt/ 12 volt difference? posted by Jed on July 20, 2004 at 06:22:44:
The coil won't care too much but the spark plugs will. For example, if a 12 volt coil with 12 volts applied supplies 30,000 volts to the spark plugs then applying 6 volts to the 12 volt coil will supply 15,000 to the plugs. Your right, to use a resistor with a 6 volt coil in a 12 volt system. Back in the late '50s and proir to electronic ignitions, a lot of the 12 volt systems by-passed a resistor during starting and then placed the resistor in the circuit after starting, there by giving a hotter spark for good starting.
K-Mo
Post a Followup
: Re: Re: Re: Farmall H coil 6 volt/ 12 volt difference?
