Re: Farmall H coil 6 volt/ 12 volt difference?
Posted by Jed on July 20, 2004 at 06:22:44 from (66.212.143.210):
In Reply to: Farmall H coil 6 volt/ 12 volt difference? posted by Farm w/Junk on July 20, 2004 at 05:20:57:
The 12 volt coil doesn't know any difference. If you put 6 volts across it , it will perform quite well. A coil is simply a winding. If you run a 12 volt system, simply add a chrysler resistor on the hot wire to the coil. They sell for about $3 to $5 at any autoparts. All they do
is reduce the voltage by 50%.
Post a Followup
: Re: Re: Farmall H coil 6 volt/ 12 volt difference?
