Re: Leaking gas
Posted by Jeff In Ontario on July 20, 2004 at 13:34:18 from (65.94.53.21):
In Reply to: Leaking gas posted by BT Jack on July 20, 2004 at 13:29:40:
I had this same problem 2 wks ago., it was a stuck float which overfilled the carb & leaked. My advice is to do what I ended up doing which is to rebuild the carb. ---Jeff
Post a Followup
: Re: Re: Leaking gas
