Re: Re: Leaking gas
Posted by Greg-N-CA on July 21, 2004 at 05:48:16 from (165.121.167.34):
In Reply to: Re: Leaking gas posted by Jeff In Ontario on July 20, 2004 at 13:34:18:
I had the same problem on my B, I replace the sediment bowl assembly and rebuilt the carb. This combination solved the problem. Now about the timing cover seal.........
Post a Followup
: Re: Re: Re: Leaking gas
