Re: harmonic balancer questions
Posted by Allan in NE on July 28, 2004 at 06:33:57 from (148.63.132.164):
In Reply to: harmonic balancer questions posted by Dan on July 28, 2004 at 06:06:37:
Mornin' Dan,
How goes the struggle? :>)
The harmonic dampener "absorbs" the (harmonic) torsional vibration of that crankshaft, which normally will start happening at about 1000 to 1500 rpm crankshaft speed; this happens on all engines.
At this speed, the crank is actually trying to 'warp' along its lengthwise axis and is trying to make the ends of the crank rotate in a larger "arc" instead of staying true in a straight line.
A bad dampener can show up in one of two ways and usually involves the rubber tearing loose from either the hub or the weight: Sometimes it will tear loose & ‘slip’ around the rotational axis and the timing marks are not where they should be. Or, at other times, the engine will vibrate when it reaches this 1000 to 1500 rpm range. It is kinda like a rattlesnake, once you are accustomed to it, you never forget it.
Did you hurt the dampener by putting it on cold? Nope, not as long as you were working on the "hub" portion of the unit and not the outer weight. Beating or pressing on the outer weight could cause it to tear all over again.
Hope this helps,
Allan
Post a Followup
: Re: Re: harmonic balancer questions
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
