Re: No voltage at coil
Posted by lee on August 01, 2004 at 17:54:28 from (24.24.95.246):
In Reply to: No voltage at coil posted by Terry on August 01, 2004 at 17:14:40:
Unclear, what you wrote. Be more specific. 6 Volt system? This Cub is positive or negative ground? Where exactly are you measuring this voltage? From + on coil to ground? From - on coil to ground. What side of coil goes to the switch? Assuming a 6 volt system, whatever the polarity, you should have 6 volts (it may read + or - depending on polarity) to ground at the coil terminal that leads to the ignition switch with the key on and the breaker points open. You should have 6 volts at that same spot with breaker points closed. You should see 6 volts across the 2 coil terminals with breaker points closed and zero volts across the coil terminals with breaker points open. There are many things to look for. The feed from bat to switch may be bad, the switch may be bad (jumper across it) the wire from switch to coil may be bad, the wire from coil to points may be bad (look for a short to ground where it passes into the distributor), the points may be closed shut, the condensor may be shorted to ground, the coil may be shorted internally.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
