Re: VAPOR LOCKED M ???
Posted by Superih on August 02, 2004 at 15:14:37 from (12.159.33.19):
In Reply to: VAPOR LOCKED M ??? posted by BRENT on August 01, 2004 at 19:14:34:
The resistor is getting too hot. I have an MTA that used to do the same thing if you where in the field all day. Put an internal resistor 12 volt coil on. That should do it.
Post a Followup
Subject:
