Re: Still at the 460
Posted by MN Scott on August 07, 2004 at 06:43:07 from (206.9.216.66):
In Reply to: Still at the 460 posted by Kelly C on August 06, 2004 at 20:24:55:
Have you checked your voltage on each side of the resitor. Once had a tractor with a bad ignition switch. Also make sure your distbuter shaft bushings are tight, no movement, if the are not point gap will change with rpm. As other posters have said make sure your gear timing/cam timing are correct. If you allready have'nt done it put a timing light on it and slowly increase rpm you should see steady advance. Also I've heard of the intake cracking or rusting thru in the heat riser area causing a vacum leak that you can't see. But a vacum leak usally affects idle not high speed. Its my feeling that its an ignition/timing problem somewears.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
