Re: Still at the 460
Posted by riverbend on August 07, 2004 at 11:11:39 from (208.160.34.102):
In Reply to: Still at the 460 posted by Kelly C on August 06, 2004 at 20:24:55:
Kelly,
Is there anyway to find out what was done to the tractor before you bought it ? The problem could be from a bungled repair i.e. cam timing is off. When you check the valve adjustment, check to see that the rockers are all moving the same amount.
Since pulling the choke out improves the situation, I would still have a look at the carb / fuel system. Can you run it with the air cleaner off ? If so, will it clear up if you spray some gas or carb cleaner into the carb ? If it does, I'd keep on that track. As you have a 'new' carb that acts the same way, I would then lean towards an air leak or low fuel flow.
Greg
Post a Followup
Subject:
