Re: Still at the 460
Posted by AW on August 07, 2004 at 14:44:44 from (142.161.9.218):
In Reply to: Still at the 460 posted by Kelly C on August 06, 2004 at 20:24:55:
Have you checked for a leak at the intake manifold? I had a school bus which acted much the same way--poor idle, no power, poor response to the accelerator, would only run with the choke out (reducing the amount of air through the carb compensated for the leakage around the manifold). It turned out to have a warped intake manifold which leaked as it warmed up, so it started okay when cold and got progressively worse as everything heated up and expanded.
Post a Followup
Subject:
