Re: Still at the 460
Posted by Hermit on August 08, 2004 at 15:43:03 from (69.21.48.16):
In Reply to: Still at the 460 posted by Kelly C on August 06, 2004 at 20:24:55:
I would get the manual out and check that the float level is set by the book. If the float level is too low, more vacuum is required to pull the gas up the venturi (i.e close the choke slightly). The adjustment screw may also have little effect since the lowered float valve is now controlling the fuel flow instead of the screw. However, it would idle OK since the idle mixture only relies on throttle plate vacuum. Good luck.
Post a Followup
Subject:
