Re: fuel strainer removal, super C
Posted by MN Scott on August 09, 2004 at 06:48:13 from (206.9.216.70):
In Reply to: fuel strainer removal, super C posted by Ken2 on August 08, 2004 at 23:16:24:
The srainer is threaded in to the tank. It might have fused to the tank over time because it is made auluminum that reacts with steel. You just have to use your hands may be a vice grip and hope it dosen't break off. Unless it leaks or is damaged you should not have to remove it just flush it out good. Good luck.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
