Re: fuel strainer removal, super C
Posted by ken2 on August 09, 2004 at 08:28:46 from (66.84.75.4):
In Reply to: Re: fuel strainer removal, super C posted by MN Scott on August 09, 2004 at 06:48:13:
Well, that's good to know. Right hand thread I hope(?) I am going to line the tank, and think the job will be done best with the strainer removed and a plug in that hole. I can just put the strainer in a vise and twist the tank. That should give plenty of leverage.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
