Re: Int 384 Diesel Problem
Posted by JB on August 22, 2004 at 09:08:07 from (24.157.143.220):
In Reply to: Int 384 Diesel Problem posted by Gary_N_WV on August 21, 2004 at 19:03:04:
Hi, had a similar problem with a B414D which is the older brother of the 384. When you went up a hill you had to give it almost full throttle and then going down hill it would run at max RPM and had to back off the throttle.
The problem turned out to be strip of rubber from the Diesel fuel storage tank filler hose had got inside the fuel tank of the B414D and every time you went up a hill it restrict the flow of Diesel fuel to the injector pump. The gouvenor inside the injector pump would attempt to compensate.
Look for the simple solutions first.
Good luck.
JB
Post a Followup
Subject:
