Re: Rod bearings on my 300
Posted by scotty on August 28, 2004 at 05:43:27 from (199.231.49.128):
In Reply to: Rod bearings on my 300 posted by Kelly C on August 27, 2004 at 22:08:48:
Hi Kelly,
Sorry to hear that the intake manifold gasket wasnt the problem on your 460.
On another note, I wouldnt use any emery on those bearings, if any grit gets onto that bearing material your gonna spin a bearing. Just my thoughts. Good luck.
scotty
Post a Followup
Subject:
