Re: International Super C
Posted by CNKS on September 04, 2004 at 18:39:55 from (207.178.96.213):
In Reply to: International Super C posted by Rob McGee on September 03, 2004 at 20:52:54:
The C123 is a small engine, thus it starts very easily on 6 volts. If it still has a generator, it was probably converted to 12 volts, it needs to be changed back (I don't know the details). The 6 volt starter works fine on 12 volts so it probably was not changed. Otherwise all you need is large battery cables, 1 or 2 gauge. The 4 of 6 gauge 12 volt cables are too small. Set it up with negative ground and be sure to polarize the generator.
Post a Followup
Subject:
