Re: IH 560 D seems stuck in gear
Posted by Chris Brown on September 10, 2004 at 18:52:28 from (209.206.208.23):
In Reply to: IH 560 D seems stuck in gear posted by minniemolineman on September 09, 2004 at 22:11:13:
I got in on this discussion a little late, but my old 560 will lock in 2nd gear if someone tries to shift from 2nd to neutral while standing on the ground,it shifts fine if you're on the tractor,something about a worn out shifter and pulling on it from an odd angle. Ocasionally I can wiggle the shifter back into 2nd gear and get it right,but usually I have to pull the shifter cap off and use a long screw driver to line up the shift rails. I usually don't have any trouble till someone else drives the tractor,someone who does'nt know just how to shift it right.
Post a Followup
Subject:
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
