Re: Electrical Mess - HELP!
Posted by Bob Quale on September 11, 2004 at 05:07:21 from (204.60.98.140):
In Reply to: Electrical Mess - HELP! posted by Phil from Maryland... on September 10, 2004 at 16:20:19:
First I would do a compression check to eliminate a valve or piston problem, next ajust the carb, at idle, the idle screw should be set for max rpm and smoothness, the high speed screw the same, with the govenor open.
Because it misses all over, and is some what eratic. I personally think it is your distributor cap. Maybe wet or cracked. I would replace it.
Bob
Post a Followup
Subject:
