Re: Problem with touch control
Posted by Peabody on September 13, 2004 at 05:32:30 from (66.191.152.242):
In Reply to: Problem with touch control posted by Sam in NJ on September 13, 2004 at 05:29:03:
More than likely, a bad drive gear seal in your hydraulic pump is allowing the fluid to run into the oil pan. Check the engine oil level. Is it high? Seal and o rings for the pump are a few dollars at your IH dealer and disassembly and repair of the pump is pretty straight-forward and easy.
Post a Followup
Subject:
