Re: Farmall H Clutch Problems
Posted by rustyfarmall on September 13, 2004 at 15:17:34 from (207.32.13.212):
In Reply to: Farmall H Clutch Problems posted by HogWild on September 13, 2004 at 13:22:00:
So you are saying that it makes no difference whether the clutch pedal is down or up? If that is the case, more than likely the clutch disc has become rusted to the flywheel. Try driving the tractor with the clutch pedal down, and try to make the tractor stop by using the brakes. This will usually work, may take several tries. If that doesn't work, the clutch may be replaced without splitting the tractor, but we can get into that later.
Post a Followup
Subject:
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
