Re: HM Hydraulics--again
Posted by Theman on September 17, 2004 at 12:48:36 from (65.248.77.5):
In Reply to: Re: HM Hydraulics--again posted by Allan in NE on September 17, 2004 at 12:16:00:
Allan, a little further explanation on what John mentioned: The delay functioned more as a pressure relief valve would. It was designed to divert the flow to the rear cylinder after the front cylinders had "bottomed out." If you are only using the rear port with the front ones plugged, there is no delay since the valve lifts immediately due to the rapid pressure rise from being "dead headed."
Now, what you're describing in the window sill indeed sounds like a check valve. You don't want to plumb these into your Liftall system since the hydraulic oil must flow in both directions.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
