PTO on IH 706 will not operate
Posted by Andy R on September 18, 2004 at 19:15:51 from (69.66.62.9):
IH 706 PTO had been operating just fine. Put new clutch kit in 3 years ago. Ran 5 foot batwing mower this summer fine. Had ran an auger at idle loading out 4,000 bushels of corn off and on. Needed to pull a new wagon under so I shut the PTO off. It wouldn't start again!!!!!! Not even try to. Put some hydraulic oil in the transmission to bring it up to full. Even stuck the air hose in the transmission filler tube in case there was an air lock. Still no PTO.
Now let me give you the complete story. The roll pin which connects the PTO handle to the linkage had sheared earlier this summer. I had just been grabbing the up and down rod to pull it on. Then I would bump it down to shut it off. When I would bump it down it was pretty forceful. Did I eventually break a pin in the valve that connects the external shaft to something internal??????? Should I pull all of the valve apart????? How does it come apart?? What other things can I check so I don't have to pull the pto unit out?????
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
